[GRASS-dev] modifying the dblink it require to re-build the topology
Moritz Lennert mlennert at club.worldonline.be
Wed Nov 13 08:42:22 PST 2013
On 12/11/13 23:24, Pietro Zambelli wrote:
> On Tuesday 12 Nov 2013 20:37:24 you wrote:
>>> On the other hand, the tables are already there, we need only to
>>> link the geometry features to the existing table.
>> No, if we have a new map it should use a different attribute table
>> than the old map.
> I don't agree I prefer to avoid to have several copy of the same thing
> on my hard-disk, but I can understand your logic. :-)
It's not about redundancy, but about the fact that when you have two
maps (the old and the new) linked to the same table you will have
conflicts to resolve. Normally GRASS erases the table linked to a map
when that map is erased. So, if you link the new map to the old table
and then erase the old map, you might lose all your attribute data...
Moritz
