[GRASS-dev] Using a multi-"${GIS_OPT_X}" input in a shell for loop
Vaclav Petras
wenzeslaus at gmail.com
Wed Nov 13 08:47:19 PST 2013
On Wed, Nov 13, 2013 at 10:50 AM, Glynn Clements
<glynn at gclements.plus.com>wrote:
> Hamish wrote:
> > Nikos wrote:
> > >> for Image in `echo $GIS_OPT_MSX | tr "," "\ "` ; do echo ${Image} ;
> done
> > Curly brackets do nothing to protect the contents of a variable. Using
> them
> > tricks new bash coders into thinking they are protected when they are
> not.
> > To avoid propagating the damaging myth, only use them when you actually
> need
> > them (eg to protect the variable name from following characters, not its
> contents).
> In case it wasn't clear: putting the variable name in braces prevents
> subsequent alphanumeric characters from being interpreted as part of
> the variable name; e.g.
> echo ${hello}_world
> will substitute the value of the variable "hello", whereas
> echo $hello_world
> will substitute the value of the variable "hello_world".
> But if you want to prevent the substituted value from being re-parsed,
> double quotes must be used, e.g.:
> echo "$hello"
> Example:
> $ hello='hi there'
> $ echo $hello
> hi there
> $ echo "$hello"
> hi there
> I remember that we had this conversation recently. What about putting some
(ba)sh(ell) primer into the manual?
However, I must say the same I said before. If you need some advanced bash
functionality such as `if` and `for` or even functions it is better to
use/learn Python instead.
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131113/1c92efcf/attachment.html>
