[GRASS-dev] [GRASS GIS] #2133: g.parser does call the form.py with full path
trac at osgeo.org
Wed Nov 13 16:38:39 PST 2013
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Parser | Version: svn-trunk
Keywords: parser | Platform: All
Cpu: All |
Comment(by hamish):
ps- typically scripts using g.parser need to be somewhere in the system
PATH since they run in two passes, and the second time it has forgotten
the original path (if it ever knew it, it could have been called as
"./script"). For compiled addon modules they don't need to be in the PATH
since the module is run in the same process as the parser.
try adding the directory you script is in to the PATH.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2133#comment:2>
