[GRASS-dev] Using a multi-"${GIS_OPT_X}" input in a shell for loop
Vaclav Petras
wenzeslaus at gmail.com
Wed Nov 13 16:59:39 PST 2013
On Wed, Nov 13, 2013 at 7:47 PM, Nikos Alexandris
<nik at nikosalexandris.net>wrote:
> Nikos wrote:
> > >> for Image in `echo $GIS_OPT_MSX | tr "," "\ "` ; do echo ${Image} ;
> > >> done
> Hamish wrote:
> > Curly brackets do nothing to protect the contents of a variable. Using
> them
> > tricks new bash coders into thinking they are protected when they are
> not.
> > To avoid propagating the damaging myth, only use them when you actually
> need
> > them (eg to protect the variable name from following characters, not its
> > contents).
> Maybe this should be added in /grass_addons/SUBMITTING_SCRIPTS ?
Hamish and Nikos, SUBMITTING is a great idea. That's the best place. And
once #2103 will be solved it will be ideal. The document can be much longer
then now, I believe.
I'm just not sure if this is for addons or trunk but just but it anywhere
for #2103 they might be merged.
https://trac.osgeo.org/grass/ticket/2103
And about Bash versus Python, I agree, I feel it the same, but at the end,
I always ends with Python. By the way, there is actually one thing which is
sometimes used and that is generation of bash code/script in Python and
then running it using bash command. Bit strange but powerful.
Vaclav
> Nikos
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131113/57a44234/attachment-0001.html>
