[GRASS-dev] [GRASS-user] i.landsat.toar fails to convert DNs (bands 61 and 62) to temperature for Landsat 7 scene
Nikos Alexandris nik at nikosalexandris.net
Fri Nov 15 08:37:38 PST 2013
This seems to not work again :-(.  This time using the MTL file (for the corresponding
scene): LE71260592002195SGS00_MTL.txt. No "MTLold" available in the downloaded scene.
Nikos
> > While  i.landsat.toar  works just fine with all bands in converting DNs to
> > Radiance/Reflectance (with some method=dos?), it seems, at least in once
> > case (scene LE71840312002041SGS00), it fails to convert bands 61 and 62 in
> > temperature!
> > Same happens (as described below in both G64 and G70).
> > Can anyone confirm or reject?
> [deleted stuff]
> Using the old metadata file (in this case: LE71840312002041SGS00_MTLold.txt)
> works fine.
> GRASS 6.4.3svn (wgs84_utm_z34_test):~ > r.info -r B.DOS1.ToCR.61
> min=158.263805493393
> max=338.623091571347
> GRASS 6.4.3svn (wgs84_utm_z34_test):~ > r.info -r B.DOS1.ToCR.62
> min=240.06999848884
> max=322.080084447704
> I guess it is a bug (something that got away in latest updates of
> i.landsat.toar towards the newer metadata file).  Will try to check
> further... not today though, deadlines approaching.
> Best, Nikos
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131115/1ac6e4a3/attachment.html>
