[GRASS-dev] Implementation of the High Pass Filter Additive Fusion technique (i.fusion.hpf)
Michael Barton
Michael.Barton at asu.edu
Sun Nov 17 11:47:10 PST 2013
On Nov 16, 2013, at 5:46 PM, Nikos Alexandris <nik at nikosalexandris.net>
wrote:
> " Replying to cmbarton:
> If you have an image set that is more than 8bit, I can use it to test some
> things. i.histo.match is a nice module. But its objective is different from
> histogram matching in i.pan.sharpen. So it would need modification to be
> used in this context. When I was writing i.pan.sharpen, I looked at the
> i.histo.match code but it was easier to use a much simpler algorithm. But
> since you know i.histo.match maybe you can see where the code could be
> modified to be used in i.pan.sharpen.
> Your histogram matching code matches the histogram of a source image to that
> of a target image, whereas i.histo.match matches the histogram of each given
> image to the cumulative histogram of all images. Both approaches are valid,
> and both should be available in a histogram matching module. "
I also looked at i.histo.match when I was writing i.pansharpen. IIRC, its original goal was to create an average histogram that could be applied to multiple images tiled together, so that they would have a nice consistent appearance without patching them into a single image. It is not the kind of histogram matching needed for pan sharpening, however.
I do not have an image set that is >8bit and floating point for testing. But someone on the list did not too long ago.
Any histogram matching algorithm (including a variant of i.histo.match) could be added as a drop-in method to i.pansharpen. All it needs is to take an "original" and "target" input files (the target is the file whose histogram is modified to match the original), and a "matched" output file.
Michael
>> There I don't see a 8bit limitation (I may be wrong). This might solve
>> ticket #2048.
> Note, the IHS method for example depends on the respective modules which are
> 8-bit based too if I am not wrong.
> Nikos
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
