[GRASS-dev] where are the options listed for g.parser?
Michael Barton Michael.Barton at asu.edu
Mon Nov 18 09:01:47 PST 2013
Thanks much Markus. This is a start. This is aimed at C programming, however, and only some of the keys and values transfer over to scripts. Following your link, I found additional info at: http://grass.osgeo.org/programming7/gis_8h_source.html#l00473
But again, this is aimed at creating interfaces in C. There is overlap, of course, but it is not the same.
What we need is something comprehensive along the lines of the example below. I don't know where it should live, but we've needed it for a long time. There should be a link to it in the g.parser docs, since the example given there is very simple. After quite a few years of scripting in GRASS I still don't know what all the options are or the possible values for some of the option fields.
Michael
INTRO
begin with #%Module
end with #%End
The following are required
#% description:
A brief description of the module
Takes a string with a maximum of ??? characters.
No quotation marks are needed
The following can be defined optionally
#% keywords:
The keywords field can be repeated multiple times.
A string used for searching for the command
Takes a string with a maximum of ??? characters. Single words are preferred.
#% overwrite:
Accepts the generic overwrite flag
Takes values: yes, no
ARGUMENTS
begin with #%option
end with #%end
#% key:
A short string identifying the entry field in the GUI
Takes a string with a maximum of ??? characters. Single words or a very few words are preferred.
#% description:
A string describing the information needed for the field
FLAGS
begin with #%flag
end with #%end
#% key:
A single character that activates the flag
Takes a string with a maximum of 1 character
#% description:
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 	480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Nov 18, 2013, at 5:40 AM, Markus Neteler <neteler at osgeo.org>
 wrote:
> On Mon, Nov 18, 2013 at 10:15 AM, Maris Nartiss <maris.gis at gmail.com> wrote:
>> Hello Michael,
>> recently there was a request about GUI prompting with hints to documentation:
>> http://lists.osgeo.org/pipermail/grass-dev/2013-November/066267.html
>> Right next to the gisprompt is also a pointer to standard options:
>> http://grass.osgeo.org/programming7/parser__standard__options_8c.html
> I have added the progman link to
> http://grasswiki.osgeo.org/wiki/Module_command_line_parser
> Markus
