[GRASS-dev] [GRASS GIS] #2134: Create a general exit-safe interface to C libraries
trac at osgeo.org
Mon Nov 18 20:07:10 PST 2013
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Python ctypes | Version: svn-trunk
Keywords: G_fatal_error, exit, multiprocessing | Platform: All
Cpu: Unspecified |
Comment(by wenzeslaus):
Thanks Soeren, this is what I hoped for and I'm looking forward how this
will continue. I just quickly looked at this topic for now. So, just some
small notes now.
I needed to do this changes to get it working:
#!diff
@@ -19,12 +19,13 @@
from multiprocessing import Process, Lock, Pipe
import logging
from ctypes import *
-from core import *
+from grass.script.core import *
import grass.lib.gis as libgis
import grass.lib.raster as libraster
import grass.lib.vector as libvector
import grass.lib.date as libdate
import grass.lib.raster3d as libraster3d
+from datetime import datetime
I though I understand how it works with exceptions and doctest but
apparently not, even I tried verbose mode:
python -m doctest -v c_library_interface.py
Anyway test passes. Would it be possible to write a test also for the case
of waiting, killing and restarting the server? I mean the case when I run
something with `call_no_wait(function=aaa)`, it runs for a long time,
meanwhile I call `call(function=bbb)` but then `bbb` fails and kills the
server. Does this make sense?
About the interface. I'm not sure about how to report errors. The
functions might need to accept keyword arguments in some way. How to deal
with objects, e.g. how to use pyGRASS through this?
I was not thinking about how to deal with wrapping all C functions. But
maybe manual wrapping it is inevitable if we want really Python(ic)
interface. We already have pyGRASS for this reason.
The last not is about naming. Although it is a well established practice
in GRASS that things are named with two or more different names, I would
suggest to use only one name for newly created things. We are at the
beginning, we can always rename but it would be safer to use one name at
time. `*C*Interface` is a nice name (although it it might by also
`*Python*Interface`) but it is more for the particular implementation
(interface for temporal framework or to messages) than for the general
thing (server). `RPCServer` is very general, not sure about that. What
about `CFunctionCaller`? I also heard suggestion `NoGFatal_Huray!!!` from
someone here but that's not a valid Python identifier, although, with
unicode identifiers, there might be a way. No strong opinion here.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2134#comment:2>
