[GRASS-dev] installing GRASS 7 on Ubuntu issue
Maris Nartiss maris.gis at gmail.com
Tue Nov 19 00:56:39 PST 2013
Hello,
as I don't run Ubuntu, could you, please, explain what exactly is
happening. "Skips GUI" sounds too board to understand "when" and "how"
skips. If it's related to compilation, check presence of *-dev
packages. If it's a problem with starting up, run from terminal to get
meaningful error message.
Maris.
2013/11/18 Michael Barton <Michael.Barton at asu.edu>:
> Hi Hamish,
> The instructions you sent, and added to the WIKI, worked great for
> installing GRASS 7 on 2 Ubuntu boxes. But on the 3rd, it won't install the
> GUI. We've made sure that wxpython (2.8.12.1) and wxwidgets are installed,
> but when GRASS installs, it simply skips the GUI. I assume that it does that
> because it cannot find wxpython/wxwidgets.
> Any idea of how to get around that?
> Thanks
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
