[GRASS-dev] installing GRASS 7 on Ubuntu issue
Rashad M mohammedrashadkm at gmail.com
Tue Nov 19 12:57:35 PST 2013
yes. this was a bug in packaging which I couldnt get time to fix. But
installing grass-gui package will help to solve the problem.
sudo apt-get install grass-gui
sudo apt-get install grass should install everything as this is a virtual
package but it not doing it right way. I may find some time this week to
fix these and merge some very important patches from debianGIS.
To sum up for now
you need to install grass like
apt-get install grass-core grass-gui
Let me know if this works so that i can confirm this issue.
On Tue, Nov 19, 2013 at 4:14 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
> Turns out that the GUI is a separate download and installation. That seems
> odd to me, but we managed to solve this.
> Michael Barton
> School of Human Evolution &Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> ...Sent from my iPad
> > On Nov 19, 2013, at 1:56 AM, "Maris Nartiss" <maris.gis at gmail.com>
> wrote:
> > Hello,
> > as I don't run Ubuntu, could you, please, explain what exactly is
> > happening. "Skips GUI" sounds too board to understand "when" and "how"
> > skips. If it's related to compilation, check presence of *-dev
> > packages. If it's a problem with starting up, run from terminal to get
> > meaningful error message.
> > Maris.
> > 2013/11/18 Michael Barton <Michael.Barton at asu.edu>:
> >> Hi Hamish,
> >> The instructions you sent, and added to the WIKI, worked great for
> >> installing GRASS 7 on 2 Ubuntu boxes. But on the 3rd, it won't install
> the
> >> GUI. We've made sure that wxpython (2.8.12.1) and wxwidgets are
> installed,
> >> but when GRASS installs, it simply skips the GUI. I assume that it does
> that
> >> because it cannot find wxpython/wxwidgets.
> >> Any idea of how to get around that?
> >> Thanks
> >> Michael
> >> ____________________
> >> C. Michael Barton
> >> Director, Center for Social Dynamics & Complexity
> >> Professor of Anthropology, School of Human Evolution & Social Change
> >> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> >> fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
> >> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131119/3fc404cd/attachment.html>
