[GRASS-dev] [GRASS GIS] #2134: Create a general exit-safe interface to C libraries
trac at osgeo.org
Wed Nov 20 14:36:33 PST 2013
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Python ctypes | Version: svn-trunk
Keywords: G_fatal_error, exit, multiprocessing | Platform: All
Cpu: Unspecified |
Comment(by huhabla):
Replying to [comment:2 wenzeslaus]:
> Thanks Soeren, this is what I hoped for and I'm looking forward how this
will continue. I just quickly looked at this topic for now. So, just some
small notes now.
> I needed to do this changes to get it working:
> #!diff
> @@ -19,12 +19,13 @@
> from multiprocessing import Process, Lock, Pipe
> import logging
> from ctypes import *
> -from core import *
> +from grass.script.core import *
> import grass.lib.gis as libgis
> import grass.lib.raster as libraster
> import grass.lib.vector as libvector
> import grass.lib.date as libdate
> import grass.lib.raster3d as libraster3d
> +from datetime import datetime
Thanks for the fix, the new version should work now in any directory.
> I though I understand how it works with exceptions and doctest but
apparently not, even I tried verbose mode:
> python -m doctest -v c_library_interface.py
Please try:
python c_library_interface.py -v
> Anyway test passes. Would it be possible to write a test also for the
case of waiting, killing and restarting the server? I mean the case when I
run something with `call_no_wait(function=aaa)`, it runs for a long time,
meanwhile I call `call(function=bbb)` but then `bbb` fails and kills the
server. Does this make sense?
Yes it does, but i was not able to fix the deadlock that appeared when
mixing "waiting calls" with "no waiting calls" and a fatal error killed
the subprocess. So i removed the no wait calls from the server interface.
> About the interface. I'm not sure about how to report errors. The
functions might need to accept keyword arguments in some way. How to deal
with objects, e.g. how to use pyGRASS through this?
In the latest implementation the subprocess creates an exception that is
send through the pipe to the server and is raised there.
If an object is picklable then it can be send between processes.
> I was not thinking about how to deal with wrapping all C functions. But
maybe manual wrapping it is inevitable if we want really Python(ic)
interface. We already have pyGRASS for this reason.
> The last not is about naming. Although it is a well established practice
in GRASS that things are named with two or more different names, I would
suggest to use only one name for newly created things. We are at the
beginning, we can always rename but it would be safer to use one name at
time. `*C*Interface` is a nice name (although it it might by also
`*Python*Interface`) but it is more for the particular implementation
(interface for temporal framework or to messages) than for the general
thing (server). `RPCServer` is very general, not sure about that. What
about `CFunctionCaller`? I also heard suggestion `NoGFatal_Huray!!!` from
someone here but that's not a valid Python identifier, although, with
unicode identifiers, there might be a way. No strong opinion here.
The latest RPC server incarnation does not care what kind of functions it
should call, hence it is very generic and takes care about killed
subprocesses. You can define any arbitrary function with arguments that
are picklable and pass it to the RPC server to call it in the subprocess.
But maybe it would be better to use sharedctypes memory in case of
digitizing rather than a pipe?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2134#comment:11>
