[GRASS-dev] i.pca doesn't have the '--o' flag
Vaclav Petras wenzeslaus at gmail.com
Thu Nov 21 17:48:18 PST 2013
On Thu, Nov 21, 2013 at 5:09 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On the contrary: r.lake offers two overwrite flags :p
r.lake has:
-o   Overwrite seed map with result (lake) map
which is distinct from
--o   Allow output files to overwrite existing files
I think that -o just overwrites input seed map by result. While --o
specifies that existing map specified by `lake` can be overwritten.
However, -o should be accepted only when --o is provided (not tested).
Moreover, it seems that -o and --o are confusing.
I actually wanted to change r.lake parameters and flags to be more standard.
xy -> G_OPT_M_COORDS
wl -> water_level
lake -> output?
elevation -> input?
-o -> ?
But I stopped at -o because it might need some larger changes. lake/output
option is not required because of the possibility of overwriting seed
raster input map. Interesting option, but it creates confusion. It is
needed? Maybe.
http://grass.osgeo.org/grass70/manuals/r.lake.html
https://svn.osgeo.org/grass/grass-addons/grass7/raster/r.lake.series/r.lake.series.py
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131121/fc801d1c/attachment.html>
