[GRASS-dev] [GRASS GIS] #2098: i.vi gari wrong formula?
trac at osgeo.org
Fri Nov 22 14:46:36 PST 2013
Reporter: kristinah | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 7.0.0
Component: Imagery | Version: svn-trunk
Resolution: | Keywords: i.vi
Platform: Unspecified | Cpu: All
Changes (by kristinah):
* status: closed => reopened
* resolution: fixed =>
Comment:
Actually, the formula I provided was also wrong. The correct formula has
the "+" in a different position
GARI = ( nirchan - (greenchan- (bluechan - redchan))) /
( nirchan + (greenchan - (bluechan - redchan)))
This was taken from the article where the formula was actually defined:
Gitelson, Anatoly A.; Kaufman, Yoram J.; Merzlyak, Mark N. (1996)
Use of a green channel in remote sensing of global vegetation from EOS-
MODIS
Remote Sensing of Environment 58 (3), 289-298.
DOI: 10.1016/s0034-4257(96)00072-7
When reading the explanation about the meaning of the index in this
article, it became clear to me, that "indexdatabase.de" must be wrong.
Sorry for pointing you in the wrong direction first!
Replying to [ticket:2098 kristinah]:
> The formula for GARI in the manual
(http://grass.osgeo.org/grass70/manuals/i.vi.html) seems to be wrong. As
it is now, the result would always be 1.
> It is
> GARI = ( nirchan - (greenchan-(bluechan - redchan))) /
> ( nirchan- (greenchan-(bluechan - redchan)))
> It should be (e.g. according to
http://www.indexdatabase.de/db/i-single.php?id=363)
> ( nirchan- (greenchan+(bluechan - redchan)))
> As the formula in the manual seems to be taken from code, the code might
be wrong as well. I did not test the function, only read the manual
online.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2098#comment:3>
