[GRASS-dev] compilation of grass on AIX 7.1
Markus Metz
markus.metz.giswork at gmail.com
Mon Nov 25 01:25:49 PST 2013
if some libraries are in a non-standard location, you might need to add
-Wl,-bsvr4,-R,/opt/freeware/lib
or equivalent to LDFLAGS [0].
Markus M
[0] http://grasswiki.osgeo.org/wiki/Compile_and_Install#AIX
On Sun, Nov 24, 2013 at 8:16 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sun, Nov 24, 2013 at 5:07 PM, Glynn Clements
> <glynn at gclements.plus.com> wrote:
>> Markus Neteler wrote:
>>> Any hints how to "inject" libstdc++.so for those modules which depend
>>> on $(GPROJLIB)?
>>> Maybe a trivial issue but I just don't know what to change.
>> AFAICT, libgrass_gproj only requires libstdc++ because of GDAL.
> Yes, I see.
>> So the definition of GDALLIBS in Platform.make should include -lstdc++
>> (and anything else which is required for C++ support).
> Unfortunately adding it:
> svn diff include/
> Index: include/Make/Platform.make.in
> --- include/Make/Platform.make.in (revision 58291)
> +++ include/Make/Platform.make.in (working copy)
> @@ -157,7 +157,7 @@
> LAPACKINC = @LAPACKINC@
> #GDAL/OGR
> -GDALLIBS = @GDAL_LIBS@
> +GDALLIBS = @GDAL_LIBS@ -lstdc++
> GDALCFLAGS = @GDAL_CFLAGS@
> USE_GDAL = @USE_GDAL@
> USE_OGR = @USE_OGR@
> ... does not help. I checked, it is present in
>> However, I don't understand why this would only affect libgrass_gproj
>> and not other libraries which require GDAL.
> Indeed it does, I looped over it now. Here the reduced list of failure
> (the others ldd checks report no error):
> libgrass_cluster.7.0.svn.so needs:
> /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_imagery.7.0.svn.so
> /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_raster.7.0.svn.so
> /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_gis.7.0.svn.so
> /usr/lib/libc.a(shr_64.o)
> /usr/lib/libpthread.a(shr_xpg5_64.o)
> /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_vector.7.0.svn.so
> /opt/freeware/lib/libiconv.a(libiconv.so.2)
> /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_datetime.7.0.svn.so
> /usr/lib/libz.a(libz.so.1)
> /unix
> /usr/lib/libcrypt.a(shr_64.o)
> Cannot find libstdc++.a(libstdc++.so.6)
> /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_dbmiclient.7.0.svn.so
> /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_dbmibase.7.0.svn.so
> /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_dgl.7.0.svn.so
> /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_dig2.7.0.svn.so
> /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_linkm.7.0.svn.so
> /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_rtree.7.0.svn.so
> /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_btree2.7.0.svn.so
> /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_gproj.7.0.svn.so
> Cannot find libgcc_s.a(shr.o)
> /usr/lib/libc.a(shr.o)
> /usr/lib/libcrypt.a(shr.o)
> libgrass_gproj.7.0.svn.so needs:
> /unix
> The complete list I have put here:
> http://pastebin.com/VXv9nGkG
> So two more libs need to somehow be added. Maybe a simple Makefile
> magic but I don't see what to do.
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
