[GRASS-dev] using libpath + ":" + in grass70 unsupported operand type
Yann Chemin
ychemin at gmail.com
Mon Nov 25 19:28:56 PST 2013
Hi Vaclav,
on my 64 bit machine, none of this happens.
Will check back home tonight...
Cheers,
Yann
On 25 November 2013 21:39, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Mon, Nov 25, 2013 at 10:55 AM, Yann Chemin <ychemin at gmail.com> wrote:
>> Hi,
>> ~/grass_dev$ grass70
>> Traceback (most recent call last):
>> File "/usr/local/bin/grass70", line 1267, in <module>
>> load_env()
>> File "/usr/local/bin/grass70", line 753, in load_env
>> os.environ['LD_LIBRARY_PATH'] = libpath + ":" + isislibpath + ":" +
>> isis3rdparty
>> TypeError: unsupported operand type(s) for +: 'NoneType' and 'str'
>> : is certainly not considered a string, but I cannot force it to be
>> string either... Any idea?
> Hi Yann,
> I'm not sure if I understand your situation, anyway:
> My line 753 in lib/init/grass.py says:
> ... libpath + os.pathsep + isislibpath + os.pathsep + isis3rdparty
> os.pathsep is for sure type str as well as ":" literal is type str.
> I would say that one of libpath, isislibpath and isis3rdparty is None
> although lines above seems that they sets everything.
> Can you debug your code? Simple print before line 753 should be enough:
> print libpath, isislibpath, isis3rdparty
> As far as I know, the print will not break the start up, so it should work.
> Vaclav
> Thanks
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131126/f75cd0cc/attachment.html>
