[GRASS-dev] [GRASS GIS] #2134: Create a general exit-safe interface to C libraries
trac at osgeo.org
Fri Nov 29 04:00:26 PST 2013
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Python ctypes | Version: svn-trunk
Keywords: G_fatal_error, exit, multiprocessing | Platform: All
Cpu: Unspecified |
Comment(by huhabla):
Pietro and i investigated the possibility of a PyGRASS vector RPC
interface in more detail off-list. We came to the conclusion that the
design of PyGRASS does not allow the implementation of a RPC interface as
suggested in this ticket. The main problem is that the most important
PyGRASS vector geometry classes make use of C-library structures
internally to massively speed up processing. The vector C-library
structures (Map_info, line_pnts, line_cats, ...) are managed by the vector
C-library using dynamic memory allocation. Such structures can not be
automatically serialized (pickled) by Python. But instances of the
geometry classes (Point, Line, Isle, Area, ...) must be exchanged by the
RPC interface for reading and writing of vector maps. To allow the
exchange of geometries all these classes must be rewritten and reduced in
their functionality. All functions that may call G_fatal_error() must be
removed from the geometry classes. An additional abstraction layer must be
implemented to convert the line_pnts and line_cats data into picklable
Python objects and vice verse.
Making PyGRASS RPC conform will result in much slower vector processing
and reduced functionality. The only benefit would be that persistent
applications, like the GUI, can use PyGRASS via RPC.
However, Pietro and i came to the conclusion that the effort to modify
PyGRASS to be RPC conform is to large and the benefits to low. We suggest
a dedicated vector editing RPC interface that calls the vector C-library
functions in the RPC subprocess directly, or that make use of PyGRASS in
the RPC subprocess but converts the geometry objects into picklebale
Python objects.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2134#comment:17>
