[GRASS-dev] v.clean tool=break fails
Markus Metz
markus.metz.giswork at gmail.com
Sat Nov 30 10:11:14 PST 2013
On Sat, Nov 30, 2013 at 6:02 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi Markus,
> 2013/11/30 Markus Metz <markus.metz.giswork at gmail.com>:
>>> Tool: Break lines at intersections
>>> 0..ERROR: Nodes not available for line 11725
>>> Defining `type` explicitly helps
>>> $ v.clean in=x3 out=x4 tool=break --o type=boundary
>> Fixed in r58340, please test.
> thanks for super-quick fix! It seems to be OK, I found similar problem
> in `merge_lines.c` (see the attached patch).
Fixed in r58341 (it's the same fix as for breaking lines).
Markus M
