[GRASS-dev] Handling of Python scripts on MS Windows
Moritz Lennert
mlennert at club.worldonline.be
Wed Oct 2 08:53:07 PDT 2013
On 02/10/13 16:47, Vaclav Petras wrote:
> I'm always for pure, correct and clean solutions. However, I'm not
> expert neither in MS Windows registry nor in Python virtual environments
> nor in covering .py to .exe and nobody provided other implementation, so
> I provided mine which is messy but it only reflects mess which I---maybe
> just because of my lack of knowledge---see on that system.
> I don't vote for my change to be permanent if we find a different
> solution. But the fact is that scripts are not working now (for large
> number of people) and this is the only solution we have. Like with
> democracy which not perfect but it is the best political system available.
I understand the frustration, but I do agree with Glynn that sometimes
hack solutions are worse than no solution, as they cover (and make us
forget) the underlying problem. And as this is a fundamental issue, I
think we just have to be patient until someone finds the best solution.
I'm no Python expert at all, and don't have much time currently to look
any further into any of this, but have you tried the python launcher as
a possible path as outlined in [1] ?
Moritz
[1] http://lists.osgeo.org/pipermail/grass-dev/2013-July/065197.html
> Vaclav
> [r57910] https://trac.osgeo.org/grass/changeset/57910
> [r57911] https://trac.osgeo.org/grass/changeset/57911
> [#2039] http://trac.osgeo.org/grass/ticket/2039
> [#2015] http://trac.osgeo.org/grass/ticket/2015
> On Wed, Oct 2, 2013 at 7:16 AM, Glynn Clements <glynn at gclements.plus.com
> > Anna and I have fixed the script handing on MS Windows. Modules
> which are
> > Python scripts and/or are from GRASS addons and/or calls other
> modules
> > which are Python scripts didn't worked for various reasons. The
> changeset
> > r57910 should fix them all (and thus should fix #2039,
> particularly the
> > MAXREPEAT error).
> Note that I've removed the hacks from core.py. So whatever bugs they
> were trying to work around will have to be fixed where they originate.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
