[GRASS-dev] v.mapcalc
Sören Gebbert
soerengebbert at googlemail.com
Thu Oct 3 04:08:15 PDT 2013
Hi Vaclav,
2013/9/21 Vaclav Petras <wenzeslaus at gmail.com>:
> Hi,
> when I saw recent changes [1] in
> grass/trunk/vector/v.mapcalc/
> I realized that there is a v.mapcalc in trunk (compilation is disabled).
> However, here is also a v.mapcalc in GSoC project for temporal algebra [2].
> I'm wondering how they compare with each other and what is the plan?
The v.mapcalc version of the GSoC project focuses on boolean
operations between whole maps. It is not possible to access single
features like points, lines or areas. It was implemented so that
Thomas lean howto use lexer/parser and calling grass modules with
pygrass. The boolean vector operations are the basis for the spatial
part of the temporal vector algebra.
I am not quite sure what grass/trunk/vector/v.mapcalc/ is capable of,
or if there will be anyone willingly to finish this module?
GSoC v.mapcalc will stay in the google repository. My plan is to
cleanup and merge the code of the temporal algebra modules and to
implement t.rast3d.mapcalc using PLY, so there will be t.rast.mapcalc,
t.rast3d.mapcalc and t.vect.mapcalc. This code will then be moved into
the temporal framework in grass7.
Best regards
Soeren
> Best,
> Vaclav
> [1] https://trac.osgeo.org/grass/ticket/1321
> [2]
> http://grasswiki.osgeo.org/wiki/GRASS_GSoC_2013_Temporal_GIS_Algebra_for_raster_and_vector_data_in_GRASS#v.mapcalc
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
