[GRASS-dev] [GRASS GIS] #2092: v.category option=del doesn't delete any categories
GRASS GIS trac at osgeo.org
Sat Oct 5 06:18:56 PDT 2013
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-trunk
 Keywords:  v.category   |    Platform:  Linux
      Cpu:  Unspecified  |
Comment(by mmetz):
 Replying to [ticket:2092 marisn]:
 > According to v.category documentation, option=del should result in
 deleting all categories, still it does nothing - all categories are
 present after module run.
 option=del deletes all categories with the value set with the cat option.
 The cat option is by default set to 1, thus only categories with value 1
 will be deleted, as happened in the example:
 v.category input=augstumi_merged output=augstumi_merged2 option=del
 layer=1
 v.category izpildīts. 1 features modified.
 In order to delete all categories of the given layer, cat must be set to
 -1. This was nmot clear in the documentation, fixed in r57940.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2092#comment:1>
