[GRASS-dev] [GRASS GIS] #2097: r.modis install using g.extension fails
GRASS GIS trac at osgeo.org
Wed Oct 9 02:22:22 PDT 2013
 Reporter:  pierreroudier  |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  normal         |   Milestone:  7.0.0
Component:  Addons         |     Version:  svn-trunk
 Keywords:  MODIS          |    Platform:  Linux
      Cpu:  x86-64         |
 I'm having problems trying to compile r.modis on the trunk version of
 GRASS from the g.extension command. It does not seem to compile the
 pymodis library if I'm getting that right.
 I am running Ubuntu 12.04.2.
 GRASS 7.0.svn (eda-rsr):~ > g.extension ext=r.modis
 Fetching <r.modis> from GRASS-Addons SVN (be patient)...
 WARNING: gnome-keyring:: couldn't connect to:
 /tmp/keyring-CTEtVP/pkcs11: No such file or directory
 Compiling...
 /bin/sh: 1: cannot create
 /usr/local/grass-7.0.svn/locale/scriptstrings/r.modis.download_to_translate.c:
 Directory nonexistent
 sed: couldn't flush stdout: Broken pipe
 make[1]:
 [/usr/local/grass-7.0.svn/locale/scriptstrings/r.modis.download_to_translate.c]
 Error 2 (ignored)
 /usr/local/grass-7.0.svn/locale/scriptstrings/r.modis.import_to_translate.c:
 make[1]:
 [/usr/local/grass-7.0.svn/locale/scriptstrings/r.modis.import_to_translate.c]
 Error 2 (ignored)
 Installing...
 Updating metadata file...
 Installation of <r.modis> successfully finished
 GRASS 7.0.svn (eda-rsr):~ > r.modis.import
 ERROR: modis library not found
Ticket URL: <https://trac.osgeo.org/grass/ticket/2097>
