[GRASS-dev] G7: parameter standardization: n/count, min/minimum etc
Glynn Clements
glynn at gclements.plus.com
Wed Oct 9 05:10:16 PDT 2013
Markus Neteler wrote:
> we have the confusing situation of naming the same statistic in different ways:
> r.series | r.statistics2 | t.rast.aggregate.* | t.vect.what.strds
> method Aggregate operation
> options: average,count,median,mode,minimum,min_raster,maximum,
> max_raster,stddev,range,sum,variance,diversity,slope,
> offset,detcoeff,tvalue,quart1,quart3,perc90,quantile,
> skewness,kurtosis
> r.in.lidar | r.in.xyz | r3.in.xyz | r.statistics
> method Statistic to use for raster values
> options: n,min,max,range,sum,mean,stddev,variance,coeff_var,
> median,percentile,skewness,trimmean
> default: mean
> I would suggest to streamline this (and personally opt for the
> r.series way of naming the methods; e.g., the "n" is easily
> overlooked, the "count" less so).
> Also the order might be revisited and standardized...?
I suggest standardising on unabbreviated names. I'll look into using
the option-matching code for option values as well as names.
