[GRASS-dev] [GRASS GIS] #1594: 180 meridian and r.proj
trac at osgeo.org
Wed Oct 9 16:01:32 PDT 2013
Reporter: awickert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Raster | Version: svn-trunk
Keywords: r.proj, meridian | Platform: Linux
Cpu: x86-64 |
Changes (by awickert):
* version: 6.4.1 => svn-trunk
Comment:
Hi Hamish,
Sorry that I completely overlooked this bug report and let it fall by the
wayside!
Here is exactly what I am doing:
1. Importing a global gridded data set into a GRASS GIS location (we'll
call it "L1"; this is unprojected: WGS84 = EPSG 4326)
2. Creating a new GRASS GIS location (L2), in the same unprojected
coordinate system (WGS84)
3. Inside L2, setting the region to extend across the 180 meridian. In my
case, here is the computational region, which is at the same resolution as
the global gridded data:
> g.region -p
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 80N
south: 50N
west: 155E
east: 125W
nsres: 0:00:30
ewres: 0:00:30
rows: 3600
cols: 9600
cells: 34560000
4. I run the following command to import the data set, in this case, the
GEBCO_08 30-arcsecond global digital elevation model:
> r.proj loc=GlobalDatabase30as in=toponow
5. I look at the output data extent - only the part of the region to the
west of the 180 meridian is imported.
I could upload the raster, but it is huge... and this is reproducible by
just creating a map of zeros with r.mapcalc in the global location ("L1")
and trying to bring it into L2 using r.proj.
Hope this helps - sorry about the *long* delay - and happy to help with
some coding if that is required to take care of this!
Andy
PS - I just uploaded to today's svn-trunk, so the problem is current.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1594#comment:3>
