[GRASS-dev] i.segment fails
Javier Martínez-López
javi.martinez.lopez at gmail.com
Thu Oct 10 05:22:24 PDT 2013
Dear list,
I am trying to run the i.segment function but I always get the same
error during the first pass: 'invalid region id 0'. What does it mean?
can it be solved? I have read some e-mails about this problem but have
found no solution yet. Trying with different thresholds or changing
the memory limit does not work.
My output:
GRASS 7.0.svn (global_MW):/home/user/HRI/Variables > time i.segment
gr=segm out=virunga_segm_0.5 thre=0.5 mins=15 memory=50000
Pass 1:
ERROR: Invalid region id 0
real 0m2.364s
user 0m2.264s
sys 0m0.094s
version=7.0.svn
date=2013
revision=55075
build_date=2013-03-07
Thank you very much in advance!
Best regards,
Javier
