[GRASS-dev] i.segment fails
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Thu Oct 10 12:39:07 PDT 2013
Hi Javier
There was a long discussion on that issue this summer. Please have a look at:
http://osgeo-org.1560.x6.nabble.com/i-segment-invalid-region-id-0-td5066102.html
Cheers
Stefan
-----Original Message-----
From: grass-dev-bounces at lists.osgeo.org [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Javier Martínez-López
Sent: 10. oktober 2013 14:22
To: grass-dev at lists.osgeo.org
Subject: [GRASS-dev] i.segment fails
Dear list,
I am trying to run the i.segment function but I always get the same error during the first pass: 'invalid region id 0'. What does it mean?
can it be solved? I have read some e-mails about this problem but have found no solution yet. Trying with different thresholds or changing the memory limit does not work.
My output:
GRASS 7.0.svn (global_MW):/home/user/HRI/Variables > time i.segment gr=segm out=virunga_segm_0.5 thre=0.5 mins=15 memory=50000 Pass 1:
ERROR: Invalid region id 0
real    0m2.364s
user    0m2.264s
sys    0m0.094s
version=7.0.svn
date=2013
revision=55075
build_date=2013-03-07
Thank you very much in advance!
Best regards,
Javier
grass-dev mailing list
http://lists.osgeo.org/mailman/listinfo/grass-dev
