[GRASS-dev] [GRASS GIS] #2097: r.modis install using g.extension fails
trac at osgeo.org
Thu Oct 10 15:34:40 PDT 2013
Reporter: pierreroudier | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Addons | Version: svn-trunk
Keywords: r.modis | Platform: Linux
Cpu: x86-64 |
Comment(by wenzeslaus):
I see that the following is the topic for a new ticket(s). So if the
discussion will go on, we should create them.
Replying to [comment:7 neteler]:
> Replying to [comment:6 wenzeslaus]:
> [... unsolved Makefile issues...]
> > By the way, we probably have a lot of duplication with the SUBMITTING
files in the main source code (trunk and others).
> They should be actually *identical* since some people come trunk while
> others only look into Addons.
I would suggest to just link (via description and file name or via URL)
the SUBMITTING from the main source code and in addons only document
addon-specific things. ''(Reorganize SUBMITTING files for addons ticket)''
I think that people are not reading any of these files and the reason They
are not available online as HTML (as part of web page, standalone or as
part of doxygen). ''(Change SUBMITTING format ticket)''
> > More by the way, there are some invalid links (and probably invalid
info too) in SUBMITTING files:
> > * http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite
(Error: 404 Not Found)
> Maybe use this URL? http://grasswiki.osgeo.org/wiki/Test_Suite
This is probably only URL we have but, if I understand correctly, it is an
idea, not a working solution. The only solution is manually run shell
scripts (but it would be probably advantageous if they are in the format
specified by that URL).
> > * http://www.grass-gis.org/mailman/listinfo/grass-qa (Errore 404 File
non trovato)
> grass-qa URL fixed.
For me http://grass.osgeo.org/mailman/listinfo/grass-qa does not work but
the result of googling - http://lists.osgeo.org/listinfo/grass-qa - works.
However, the descriptions says ''(NOTE: currently inactive!)''.
''(Missing instructions for testing ticket)''
Ticket URL: <https://trac.osgeo.org/grass/ticket/2097#comment:8>
