[GRASS-dev] [GRASS-user] G7-gui and G64 add-on problems on Xubuntu (installation from grass/ubuntugis ppa)
Vaclav Petras
wenzeslaus at gmail.com
Mon Oct 14 06:11:48 PDT 2013
[Changing list to grass-dev, at least the traceback is compilation problem.]
On Mon, Oct 14, 2013 at 4:34 AM, Johannes Radinger <
johannesradinger at gmail.com> wrote:
> Hi all,
> I want to install G7 and G6.4.3 as well as several add-ons on a freshly
> installed Xubuntu (12.04) machine (Virtualbox) for testing purposes.
> Therefore I run following commands after Xubuntu installation and update of
> the system:
> sudo add-apt-repository ppa:grass/grass-devel
> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
> sudo apt-get update
> sudo apt-get install grass643 grass70 grass-gui grass70-gui
> However after successful installation I run into following two problems:
> 1) When I try to launch G7-gui (e.g. with standard NC example dataset) I
> get following error:
> Launching <wxpython> GUI in the background, please wait...
> GRASS 7.0.svn (nc_basic_spm_grass7):~ > Traceback (most recent call last):
> File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 143, in <module>
> sys.exit(main())
> File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 136, in main
> app = GMApp(workspaceFile)
> File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 50, in __init__
> wx.App.__init__(self, False)
> File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py",
> line 7981, in __init__
> self._BootstrapApp()
> line 7555, in _BootstrapApp
> return _core_.PyApp__BootstrapApp(*args, **kwargs)
> File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 84, in OnInit
> workspace = self.workspaceFile)
> File "/usr/lib/grass70/etc/gui/wxpython/lmgr/frame.py", line 108, in
> __init__
> self._menuTreeBuilder = LayerManagerMenuData()
> File "/usr/lib/grass70/etc/gui/wxpython/lmgr/menudata.py", line 40, in
> __init__
> MenuTreeModelBuilder.__init__(self, filename,
> expandAddons=expandAddons)
> File "/usr/lib/grass70/etc/gui/wxpython/core/menutree.py", line 69, in
> __init__
> xmlTree = etree.parse(filename)
> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1183, in parse
> tree.parse(source, parser)
> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 657, in parse
> self._root = parser.close()
> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1655, in close
> self._raiseerror(v)
> File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1507, in
> _raiseerror
> raise err
> xml.etree.ElementTree.ParseError: no element found: line 1, column 0
About the traceback, it seems as a compilation issue in the PPA. During
compilation the menudata.xml file should created in gui/wxpython/xml/ but
probably it is not.
There is a note about some changes in the repository at:
https://launchpad.net/~grass
Can someone from the Launchpad GRASS GIS team check/explain what is
happening? With this file we have problems at Mac but Ubuntu and Windows
were successfully tested (but still, the related Makefile is bit strange,
so that might be a problem).
Here is what my ls says after I run make:
$ ls gui/wxpython/xml/
grass-gxm.dtd menudata.dtd menudata.xml toolboxes.dtd
grass-gxw.dtd menudata_modeler.xml module_items.dtd toolboxes.xml
main_menu.dtd menudata_psmap.xml module_tree_menudata.xml
wxgui_items.dtd
main_menu.xml menudata.README module_tree.xml
wxgui_items.xml
$ ls dist.i686-pc-linux-gnu/etc/gui/wxpython/xml/
grass-gxm.dtd menudata_modeler.xml module_items.xml
wxgui_items.dtd
grass-gxw.dtd menudata_psmap.xml module_tree_menudata.xml
wxgui_items.xml
main_menu.dtd menudata.README module_tree.xml
main_menu.xml menudata.xml toolboxes.dtd
menudata.dtd module_items.dtd toolboxes.xml
> 2) G6.4.3. and its gui can be properly launched (no problems like
> mentioned in point 1). So here I tried to install add.ons. There I ran
> g.extension from the grass terminal but face following problem:
> GRASS 6.4.3 (gisdemo_ncspm):~ > g.extension extension=r.stream.order
> Fetching <r.stream.order> from GRASS-Addons SVN (be patient)...
> WARNING: gnome-keyring:: couldn't connect to: /tmp/keyring-U4bRKD/pkcs11:
> No such file or directory
> A r.stream.order/main.c
> A r.stream.order/description.html
> A r.stream.order/global.h
> A r.stream.order/io.c
> A r.stream.order/r_stream_order_orders.png
> A r.stream.order/order.c
> A r.stream.order/Makefile
> U r.stream.order
> Checked out revision 57991.
> Compiling <r.stream.order>...
> Makefile:12: /usr/lib/grass64/include/Make/Module.make: No such file or
> directory
> make: *** No rule to make target
> `/usr/lib/grass64/include/Make/Module.make'. Stop.
> ERROR: Compilation failed, sorry. Please check above error messages.
> I cannot add anything to the other problem but it might be similar to the
recent problem on Suse:
Suse 12.3, GRASS 6.4.3 - addons not possible to install (
http://permalink.gmane.org/gmane.comp.gis.grass.user/48209)
> So does anyone have an idea what may cause the problems. I don't think
> that the problems are related nor are they caused by my Xubuntu-Virtualbox
> setup. Do I miss any modules/packages/software that I need to install prior
> to grass? Or do I need to use different ppas for installing grass? Any help
> is of course mostly welcome!
> Both seems like a GRASS problem, particularly, compilation/packaging
problem, so there probably nothing you can do on you machine except for
checking files:
/pathtograss7/etc/gui/wxpython/xml/menudata.xml for GRASS 7
/usr/lib/grass64/include/Make/Module.make for GRASS 6 (above says 'no such
file' already)
Vaclav
Best regards,
> Johannes
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131014/c914085a/attachment.html>
