[GRASS-dev] [GRASS GIS] #2100: r.proj bounding box too small by half a cell size (-g or -p):
trac at osgeo.org
Mon Oct 14 07:06:28 PDT 2013
Reporter: awickert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: r.proj | Platform: Linux
Cpu: Unspecified |
Comment(by glynn):
Replying to [ticket:2100 awickert]:
The border-walking code uses cell centres in all cases (i.e. when
performing projection as well as when displaying the bounding box with
-p/-g).
It's possible that this is intentional, to avoid issues when the
north/south edges of either the current region or the input map extend to
the poles.
Otherwise, the fix should be reasonably straightforward: remove the half-
cell offsets from bordwalk1() in raster/r.proj/bordwalk.c.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2100#comment:1>
