[GRASS-dev] [GRASS-user] G7-gui and G64 add-on problems on Xubuntu (installation from grass/ubuntugis ppa)
Tim Michelsen timmichelsen at gmx-topmail.de
Mon Oct 14 23:03:36 PDT 2013
Dear all,
I am receiving quite some of these mails on the LP packages for both
version 6.x
& 7.x.
There are even less constructive messages like: "your PPA is broken.
just let you know. fix it"
As noted in an earlier email:
http://thread.gmane.org/gmane.comp.gis.grass.user/46947
I currently cannot devote any time to fix issues there.
I would be happy to have a larger team that could care of these.
Please request membership at:
https://launchpad.net/~grass/+join
Please have a look at the instruction here:
http://grasswiki.osgeo.org/wiki/Ubuntu_Packaging
Some time I tried to set a QGIS builder as well as I needed the new
version but is didn't work out.
Why should OSGEO4W have more up to date packages?
Let's work this out here.
Thanks for your understanding.
Kind regards,
Timme
Am 14.10.2013 16:31, schrieb Vaclav Petras:
> One little addition to this,
> On Mon, Oct 14, 2013 at 9:11 AM, Vaclav Petras <wenzeslaus at gmail.com
> <mailto:wenzeslaus at gmail.com>> wrote:
>     [Changing list to grass-dev, at least the traceback is compilation
>     problem.]
>     Hi,
>     On Mon, Oct 14, 2013 at 4:34 AM, Johannes Radinger
>     <johannesradinger at gmail.com <mailto:johannesradinger at gmail.com>> wrote:
>         Hi all,
>         I want to install G7 and G6.4.3 as well as several add-ons on a
>         freshly installed Xubuntu (12.04) machine (Virtualbox) for
>         testing purposes. Therefore I run following commands after
>         Xubuntu installation and update of the system:
>         sudo add-apt-repository ppa:grass/grass-devel
>         sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
>         sudo apt-get update
>         sudo apt-get install grass643 grass70 grass-gui grass70-gui
>         However after successful installation I run into following two
>         problems:
>         1) When I try to launch G7-gui (e.g. with standard NC example
>         dataset) I get following error:
>         Launching <wxpython> GUI in the background, please wait...
>         GRASS 7.0.svn (nc_basic_spm_grass7):~ > Traceback (most recent
>         call last):
>           File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 143,
>         in <module>
>             sys.exit(main())
>           File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 136,
>         in main
>             app = GMApp(workspaceFile)
>           File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 50, in
>         __init__
>             wx.App.__init__(self, False)
>           File
>         "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py",
>         line 7981, in __init__
>             self._BootstrapApp()
>           File
>         line 7555, in _BootstrapApp
>             return _core_.PyApp__BootstrapApp(*args, **kwargs)
>           File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 84, in
>         OnInit
>             workspace = self.workspaceFile)
>           File "/usr/lib/grass70/etc/gui/wxpython/lmgr/frame.py", line
>         108, in __init__
>             self._menuTreeBuilder = LayerManagerMenuData()
>           File "/usr/lib/grass70/etc/gui/wxpython/lmgr/menudata.py",
>         line 40, in __init__
>             MenuTreeModelBuilder.__init__(self, filename,
>         expandAddons=expandAddons)
>           File "/usr/lib/grass70/etc/gui/wxpython/core/menutree.py",
>         line 69, in __init__
>             xmlTree = etree.parse(filename)
>           File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1183,
>         in parse
>             tree.parse(source, parser)
>           File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 657,
>         in parse
>             self._root = parser.close()
>           File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1655,
>         in close
>             self._raiseerror(v)
>           File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1507,
>         in _raiseerror
>             raise err
>         xml.etree.ElementTree.ParseError: no element found: line 1, column 0
>     About the traceback, it seems as a compilation issue in the PPA.
>     During compilation the menudata.xml file should created in
>     gui/wxpython/xml/ but probably it is not.
>     There is a note about some changes in the repository at:
>     Can someone from the Launchpad GRASS GIS team check/explain what is
>     happening? With this file we have problems at Mac but Ubuntu and
>     Windows were successfully tested (but still, the related Makefile is
>     bit strange, so that might be a problem).
>     Here is what my ls says after I run make:
>     $ ls gui/wxpython/xml/
>     grass-gxm.dtd  menudata.dtd          menudata.xml
>      toolboxes.dtd
>     grass-gxw.dtd  menudata_modeler.xml  module_items.dtd
>      toolboxes.xml
>     main_menu.dtd  menudata_psmap.xml    module_tree_menudata.xml
>      wxgui_items.dtd
>     main_menu.xml  menudata.README       module_tree.xml
>     wxgui_items.xml
>     $ ls dist.i686-pc-linux-gnu/etc/gui/wxpython/xml/
>     grass-gxm.dtd  menudata_modeler.xml  module_items.xml
>      wxgui_items.dtd
>     grass-gxw.dtd  menudata_psmap.xml    module_tree_menudata.xml
>      wxgui_items.xml
>     main_menu.dtd  menudata.README       module_tree.xml
>     main_menu.xml  menudata.xml          toolboxes.dtd
>     menudata.dtd   module_items.dtd      toolboxes.xml
> it is possible to run the test of menudata.xml generation (toolboxes.py)
> using following commands (you need to be in a GRASS session):
> python toolboxes.py doctest
> python toolboxes.py test
> However, I'm not sure if this is helpful for packagers.
>         2) G6.4.3. and its gui can be properly launched (no problems
>         like mentioned in point 1). So here I tried to install add.ons.
>         There I ran g.extension from the grass terminal but face
>         following problem:
>         GRASS 6.4.3 (gisdemo_ncspm):~ > g.extension extension=r.stream.order
>         Fetching <r.stream.order> from GRASS-Addons SVN (be patient)...
>         WARNING: gnome-keyring:: couldn't connect to:
>         /tmp/keyring-U4bRKD/pkcs11: No such file or directory
>         A    r.stream.order/main.c
>         A    r.stream.order/description.html
>         A    r.stream.order/global.h
>         A    r.stream.order/io.c
>         A    r.stream.order/r_stream_order_orders.png
>         A    r.stream.order/order.c
>         A    r.stream.order/Makefile
>          U   r.stream.order
>         Checked out revision 57991.
>         Compiling <r.stream.order>...
>         Makefile:12: /usr/lib/grass64/include/Make/Module.make: No such
>         file or directory
>         make: *** No rule to make target
>         `/usr/lib/grass64/include/Make/Module.make'.  Stop.
>         ERROR: Compilation failed, sorry. Please check above error messages.
>     I cannot add anything to the other problem but it might be similar
>     to the recent problem on Suse:
>     Suse 12.3, GRASS 6.4.3 - addons not possible to install
>     (http://permalink.gmane.org/gmane.comp.gis.grass.user/48209)
>         So does anyone have an idea what may cause the problems. I don't
>         think that the problems are related nor are they caused by my
>         Xubuntu-Virtualbox setup. Do I miss any
>         modules/packages/software that I need to install prior to grass?
>         Or do I need to use different ppas for installing grass? Any
>         help is of course mostly welcome!
>     Both seems like a GRASS problem, particularly, compilation/packaging
>     problem, so there probably nothing you can do on you machine except
>     for checking files:
>     /pathtograss7/etc/gui/wxpython/xml/menudata.xml for GRASS 7
>     /usr/lib/grass64/include/Make/Module.make for GRASS 6 (above says
>     'no such file' already)
>     Vaclav
>         Best regards,
>         Johannes
>         _______________________________________________
>         grass-user mailing list
>         grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/grass-user
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
