[GRASS-dev] [GRASS GIS] #2105: Missing guidelines for testing
trac at osgeo.org
Tue Oct 15 08:14:44 PDT 2013
Reporter: wenzeslaus | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.0.0
Component: Docs | Version: svn-trunk
Keywords: testing, tests | Platform: Unspecified
Cpu: Unspecified |
I miss any kind of guide how to create test. This applies for the main
source code and the addons, C/C++ and Python, modules and code itself.
There are tests of temporal modules but it is not currently described
anywhere how they are organized.
There is also a `testsuite` directory in trunk but it is not maintained.
I've also noticed some tests running during compilation but I was never
able to find out what it is.
Some Python functions can be tested using `doctest` and Python developers
usually know how to use it. However, it is not clear how to ensure calling
from make.
There is a page about the test framework we wish to have:
* http://grasswiki.osgeo.org/wiki/Test_Suite
But since it does not exists the page creates just confusion.
There is also a mailing list about testing:
* http://lists.osgeo.org/mailman/listinfo/grass-qa
But it is not active.
''We probably also miss the testing infrastructure itself but that's
another bigger ticket. But some things exists already, so we can use
them.''
''Maybe, we need Tests component in Trac?''
Ticket URL: <https://trac.osgeo.org/grass/ticket/2105>
