[GRASS-dev] [GRASS GIS] #2109: connect error in replacement of $MAPSET
trac at osgeo.org
Wed Oct 16 03:22:50 PDT 2013
Reporter: lucadelu | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Temporal | Version: svn-trunk
Keywords: connection | Platform: All
Cpu: All |
Hi all,
when I try to use a different mapset then PERMANENT using $MAPSET variable
it is not changed with the right value but a $MAPSET directory is create
on the location path
Ticket URL: <http://trac.osgeo.org/grass/ticket/2109>
