[GRASS-dev] [GRASS GIS] #2109: connect error in replacement of $MAPSET
GRASS GIS trac at osgeo.org
Wed Oct 16 23:35:56 PDT 2013
  Reporter:  lucadelu     |       Owner:  grass-dev@…
      Type:  enhancement  |      Status:  reopened
  Priority:  normal       |   Milestone:  7.0.0
 Component:  Temporal     |     Version:  svn-trunk
Resolution:               |    Keywords:  connection
  Platform:  All          |         Cpu:  All
Changes (by lucadelu):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Replying to [comment:2 huhabla]:
 > Replying to [comment:1 huhabla]:
 > > You can use:
 > > eval `g.gisenv`
 > > To set $GISDBASE, $LOCATION_NAME and $MAPSET
 > > I will modify the code of t.connect so that instead of the shell
 variables $GISDBASE and $LOCATION_NAME the real path variables are set in
 the module help to reduce confusion.
 > Done in r58015
 Sorry I don't understand what was done, I have the same behavior of
 yesterday, If I use
 t.connect database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/tgis.db'
 the database is created in
 /grassdata/eu_laea/$MAPSET/sqlite/tgis.db
 The revision I'm using is 58021.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2109#comment:3>
