[GRASS-dev] r.in.lidar tuning
Newcomb, Doug doug_newcomb at fws.gov
Thu Oct 17 08:14:29 PDT 2013
Any thoughts on applying further filtering and using the intensity of the
return for statistical analysis?  For example, if one wanted to calculate
the mean/range/in/max/std_dev  intensity of the last returns or first
returns.
Doug
On Tue, Oct 8, 2013 at 2:37 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Oct 8, 2013 at 4:31 PM, Markus Metz
> <markus.metz.giswork at gmail.com> wrote:
> > Markus Neteler wrote:
> >> One more wish comes to mind (indeed, I started cross-porting but :-)
> >> v.in.lidar comes with a filter (which should perhaps be generalized to
> >> the nth return; or, the last *is* the nth return but then "mid" could
> >> be more than one in this case?):
> > Yes, for n returns, the first return is number 1, the last return is
> > the nth return and mid returns are all returns in between, i.e. none
> > for 2 returns. Choosing the nth return does not make sense to me.
> ok
> >>     filter   Only import points of selected return type
> >>               If not specified, all points are imported
> >>              options: first,last,mid
> >> which would be great for r.in.lidar as well to avoid that I need to
> >> split the file with las2las beforehand.
> > Why would you want to do filtering? The r.in.lidar methods min, max,
> > mean, median, percentile are not sufficient?
> I omitted to mention the sometimes existing classification of returns
> and had in mind to be able to restrict the import to e.g. ground
> points only, or the like. Then apply the methods min, max, etc only to
> the selected subset of LiDAR points.
> markusN
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of the
Interior.   Life is too short for undocumented, proprietary data formats.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131017/181fd69c/attachment.html>
