[GRASS-dev] [GRASS GIS] #2095: GRASS changes for OSGeo4W 64bit
Markus Neteler neteler at osgeo.org
Thu Oct 17 11:46:26 PDT 2013
>  Reporter:  jef          |       Owner:  grass-dev@…
>      Type:  enhancement  |      Status:  new
>  Priority:  normal       |   Milestone:
> Component:  Default      |     Version:  6.4.3
>  Keywords:  osgeo4w      |    Platform:  MSWindows 7
>       Cpu:  x86-64       |
>  I added the following change to make GRASS work on OSGeo4W 64bit.  The
>  libpng is there is build with MSVC and therefore does share the same
>  stdio, it has GDAL 1.10 and apparently 64bit Windows doesn't use special
>  symbol exports in DLLs anymore (GDAL is also build with MSVC).
> Ticket URL: <http://trac.osgeo.org/grass/ticket/2095>
Any objections to apply this?
Markus
