[GRASS-dev] ccmath compilation error
Yann Chemin
ychemin at gmail.com
Sun Oct 20 00:48:36 PDT 2013
lib/external/ccmath$ make
make lib
make[1]: Entering directory
`/home/yann/grass_dev/grass_yann/lib/external/ccmath'
gcc -g -O2 -fPIC
-I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include
-D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grasslibs"\"
-I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/house.o -c house.c
house.c: In function ‘house’:
house.c:10:6: internal compiler error: in rewrite_use_nonlinear_expr, at
tree-ssa-loop-ivopts.c:6215
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.7/README.Bugs> for instructions.
Preprocessed source stored into /tmp/cc8wc4KR.out file, please attach this
to your bugreport.
make[1]: *** [OBJ.i686-pc-linux-gnu/house.o] Error 1
make[1]: Leaving directory
make: *** [default] Error 2
GCC version
gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/i686-linux-gnu/4.7/lto-wrapper
Target: i686-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro
4.7.3-1ubuntu1' --with-bugurl=file:///usr/share/doc/gcc-4.7/README.Bugs
--enable-languages=c,c++,go,fortran,objc,obj-c++ --prefix=/usr
--program-suffix=-4.7 --enable-shared --enable-linker-build-id
--libexecdir=/usr/lib --without-included-gettext --enable-threads=posix
--with-gxx-include-dir=/usr/include/c++/4.7 --libdir=/usr/lib --enable-nls
--with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug
--enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin
--with-system-zlib --enable-objc-gc --enable-targets=all --with-cloog
--enable-cloog-backend=ppl --disable-cloog-version-check
--disable-ppl-version-check --enable-multiarch --disable-werror
--with-arch-32=i686 --with-multilib-list=m32,m64,mx32 --with-tune=generic
--enable-checking=release --build=i686-linux-gnu --host=i686-linux-gnu
--target=i686-linux-gnu
Thread model: posix
gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-1ubuntu1)
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131020/4a1cbc51/attachment.html>
