[GRASS-dev] [GRASS GIS] #2105: Missing guidelines for testing
GRASS GIS trac at osgeo.org
Tue Oct 22 14:23:42 PDT 2013
 Reporter:  wenzeslaus      |       Owner:  grass-dev@…
     Type:  task            |      Status:  new
 Priority:  normal          |   Milestone:  7.0.0
Component:  Tests           |     Version:  svn-trunk
 Keywords:  testing, tests  |    Platform:  Unspecified
      Cpu:  Unspecified     |
Comment(by huhabla):
 Replying to [comment:3 wenzeslaus]:
 > Replying to [comment:1 huhabla]:
 > > Replying to [ticket:2105 wenzeslaus]:
 > > > There is a page about the test framework we wish to have:
 > > >  * http://grasswiki.osgeo.org/wiki/Test_Suite
 > > > But since it does not exists the page creates just confusion.
 > > This page describes in very detail how the testsuite can be
 implemented for modules and libraries. Python doctests and how to
 implement automated testing in the make system are not covered. It
 includes a guideline howto implement tests for modules based on shell
 scripts. Hence it is unclear to me how this leads to confusion?
 > > However, i am all for a complete new test suite design. I would
 suggest to implement all module and Python library tests in Python, so
 that these tests can be executed independently from the OS or the used
 command line interpreter, with or without the make system.
 > For me it seems that it is not worth to build our own tests system and
 bash-like language interpreter (as proposed on the wiki page). I vote for
 writing module tests directly in Python. From my experience I was writing
 module test in bash and it is easier at the beginning but if you want to
 do something more special than calling a module and check the return code
 bash-like language is not sufficient. Moreover, we want cross platform
 tests and I think we don't want to implement bash-like syntax parser and
 interpreter for variables, if-statements, for loops in Python, although it
 sounds interesting. When writing directly in Python, the tests dependents
 on GRASS or Python process calling capabilities but they would depend
 anyway if the interpreter would be build. The only advantage in writing in
 bash-like syntax is that it can run as bash/sh... script, but Python
 script is great too, isn't it?
 It is. Writing module tests directly in Python will give us much more
 flexibility. But we have to implement a GRASS specific Python test
 framework to test and validate GRASS modules. This framework should
 provide classes and functions to test different module configurations and
 check their output with reference data automatically. The suggested
 framework in [1] is still valid in several aspects (location creation,
 cleaning, data check). I would suggest to use the PyUnit framework for
 module testing. The PyGRASS Module interface should be used to configure
 module runs. Configured modules should be run by specific test functions
 that check the module output and stdout/stderr with reference data that is
 located in the modules test directory. It should be possible to configure
 the test suite so that all modules are executed in a virtual environment
 like valgrind for memory leak checks.
 Here an PyUnit example of a r.info test:
 #!/usr/bin/python
 import unittest
 import grass.pygrass.modules as pymod
 import grass.test_suite as test_suite
 class r_info_test(unittest.TestCase):
     @classmethod
     def setUpClass(cls):
         """! Set up the test mapset and create test data for all tests
         # Create the temporary test mapset and set up the test environment
         test_suite.init()
         # Create test data for each test
         m = pymod.Module("r.mapcalc", expr="test = 1", run_=False)
         # We simply run this module, if the module run fails,
         # the whole test will be aborted
         test_suite.run_module(module=m)
     def test_flag_g(self):
         """! Test to validate the output of r.info using flag "g"
         # Configure a r.info test
         m = pymod.Module("r.info", map="test", flags="g", run_=False)
         # Run the test using the test suite functionality and check
         # the output on stdout with reference data that is located in the
         # r.info test directory
         # This function will call an exception if the module run fails
         # or if the output in comparison to the reference data is
 incorrect
         test_suite.test_module(module=m, check="stdout",
 reference="r_info_g.ref")
     def test_flag_e(self):
         """! Test to validate the output of r.info using flag "e"
         m = pymod.Module("r.info", map="test", flags="e", run_=False)
         # r.info test directory.
 incorrect
 reference="r_info_e.ref")
     @classmethod
     def tearDownClass(cls):
         """! Remove the temporary mapset """
         test_suite.clean_up()
 if __name__ == '__main__':
     unittest.main()
 [1] http://grasswiki.osgeo.org/wiki/Test_Suite
 > For the test of the library code it is clear that it must be done in
 Python as you say. I suppose that it would be tested using ctypes, am I
 right? The problem I can see is that I would like to test also `static`
 functions and this is not possible I guess.
 I see no problem in using doctests [1] and PyUnit tests [2] for Python
 library and C-library testing. There are C-library tests for the gmath,
 gpde and raster3d libraries [3,4,5]. These library tests will
 compile/create dedicated GRASS modules that can be executed in a grass
 environment ... using a PyUnit test for example. All C-library functions
 can be tested in this way.
 PyUnit tests for GRASS library functions can be implemented if the
 C-libraries are accessible using the ctype bindings. Here a PyUnit test
 example that calls C++ library functions from the vtk-grass-bridge project
 [6].
 Doctests are already widely used in the temporal framework, the temporal
 algebra and in PyGRASS, example [7].
 [1] http://docs.python.org/2/library/doctest.html
 [2] http://docs.python.org/2/library/unittest.html
 [3] http://trac.osgeo.org/grass/browser/grass/trunk/lib/gmath/test
 [4] http://trac.osgeo.org/grass/browser/grass/trunk/lib/gpde/test
 [5] http://trac.osgeo.org/grass/browser/grass/trunk/lib/raster3d/test
 [6] https://code.google.com/p/vtk-grass-
 bridge/source/browse/trunk/Raster/Testing/Python/GRASSRasterMapReaderWriterTest.py
 [7]
 http://trac.osgeo.org/grass/browser/grass/trunk/lib/python/temporal/space_time_datasets.py
 The make system must be extended to allow automated test runs ->
 http://grasswiki.osgeo.org/wiki/Test_Suite#Make_system
 This example should run the library tests.
 cd grass_trunk/lib
 make test
 Library tests are PyUnit tests in case of C-libraries that call
 ctypes functions or library module like "test.raster3d.lib". Doctests
 should be implemented in case of Python libraries like the temporal
 framework or PyGRASS.
 This example should only run raster module tests
 cd grass_trunk/raster
 make test
 The make system should use a dedicated test location in which all needed
 global test-specific data is located in the PERMANENT mapset (minimized NC
 location?). It should run all tests within a grass session using this
 location. Each test should create its dedicated temporary mapset in the
 test location by calling the "test_suite.init()" function in the class
 setup. This hopefully allows the parallel execution of tests. Hence,
 "make -j4 test" should test 4 modules in parallel. Each test will create
 its own HTML output.
 The result of the tests should be a compiled HTML document that shows
 every test run in detail. In addition, the output of valgrind about memory
 leaks should be available for each module and library test. Such HTML
 documents can be hosted on the test server that performs automatic test
 runs.
 The make system will remove all remaining temporary mapsets from the test
 location after all tests are finished.
 What a nice GSoC 2014 project. :D
Ticket URL: <http://trac.osgeo.org/grass/ticket/2105#comment:4>
