[GRASS-dev] [GRASS GIS] #2119: wxgui: attribute table manager fails with "Inconsistent number of columns in the table"
trac at osgeo.org
Fri Oct 25 06:52:36 PDT 2013
in the table"
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: table manager | Platform: Unspecified
Cpu: Unspecified |
Comment(by annakrat):
I didn't have any problems with loading the table in attribute manager,
all columns seem to be there. I am running Ubuntu with US locale. The
'`{__sep__}`' is the the separator which is used internally for
v.db.select because it's highly improbable that it could appear in the
data. Strange is that you can see only a part of the separator without the
one curly bracket. Are you running it on Windows?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2119#comment:2>
