[GRASS-dev] g.extension still broken in GRASS 7 on Mac
Michael Barton Michael.Barton at asu.edu
Fri Oct 25 15:17:46 PDT 2013
Yes!!!
This works. Thanks much Martin!
I test it with r.stream.order from the GRASS terminal and from the GUI wrapper. Both work. So now it is working better than GRASS 6.4.
One question for what Bulent is experiencing. Do Mac users need to have the Developer tools installed for g.extension to work? I'm assuming yes, but do not know for sure. Also (maybe William can offer suggestion), does it matter what SDKs are installed?
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 	480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www: 	http://csdc.asu.edu, http://shesc.asu.edu
		http://www.public.asu.edu/~cmbarton
On Oct 25, 2013, at 1:18 AM, Martin Landa <landa.martin at gmail.com>
 wrote:
> Hi,
> 2013/10/24 Glynn Clements <glynn at gclements.plus.com>:
>> You can override RUN_GISRC on the make command line if you want to use
>> a different $GISRC file.
> right, done in r58103.
> @Michael: please let us know if it works for you.
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
