[GRASS-dev] issue with vector import wrapper for v.in.ogr for GRASS 7
Anna Petrášová kratochanna at gmail.com
Tue Sep 3 07:35:41 PDT 2013
On Mon, Sep 2, 2013 at 3:20 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
>  I received a report that the wrapper for v.in.ogr is throwing an error
> when importing files of multiple types (kml and shp tested). The error in
> the terminal is:
>  pythonw2.6(5979,0xad1e72c0) malloc: *** error for object 0x6d353ed5:
> pointer being freed was not allocated
> *** set a breakpoint in malloc_error_break to debug
>  v.in.ogr works fine for the same files. So it is the wrapper.
>  This is happening in GRASS 7 r57457, compiled 16 August. That's a couple
> weeks back, so it may be fixed. If not, I can do a ticket.
this is a strange error, does this happen on certain platforms only? And
when exactly does this error appear, when you press Import?
Anna
>  Michael
>          ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
>  voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130903/59b9dc73/attachment.html>
