[GRASS-dev] GRASS70 for Ubuntu in ppa
Johannes Radinger
johannesradinger at gmail.com
Wed Sep 4 06:25:52 PDT 2013
No problem...as I said I just rolled back to precise. So no worry about
raring for the moment. On precise I am able to install grass70 from
grass-devel ppa and grass643 from ubuntugis-unstable...
However when I try to launch both from the console (freshly installed
precise) via grass64 or grass70 I get an error:
python: can't open file '/usr/lib/grass64/etc/wxpython/gis_set.py': [Errno
2] No such file or directory
resp.
python: can't open file '/usr/lib/grass70/etc/wxpython/gis_set.py': [Errno
Any idea about that?
/Johannes
On Wed, Sep 4, 2013 at 2:28 PM, Rashad M <rashadkm at gmail.com> wrote:
> there was some problem on raring and I couldn't get time to work on it.
> Anyway I will add it to my calender again and let see if I can figure it
> out. The main problem is I dont have a raring currently I need to login to
> a remote system at my university and do it. I will try this weekend and let
> you know
> On Wed, Sep 4, 2013 at 2:25 PM, Johannes Radinger <
> johannesradinger at gmail.com> wrote:
>> At the moment I also saw that the last build failed for raring...
>> so for the moment I'll reinstall precise to test grass70
>> On Wed, Sep 4, 2013 at 2:18 PM, Rashad M <rashadkm at gmail.com> wrote:
>>> Hi,
>>> the recipe was not building for raring but I enabled it and you can
>>> check back in a while
>>> On Wed, Sep 4, 2013 at 1:42 PM, Johannes Radinger <
>>>> that one is installed...thats why I am wondering.
>>>> I am running Xubuntu (latest actually todays version). The repo
>>>> is also listed (e.g. in Synaptic and I see the grass-add ons but
>>>> not the grass70)
>>>> Maybe because of my new Xubuntu version (Raring ringtail)?
>>>> On Wed, Sep 4, 2013 at 1:29 PM, Rashad M <rashadkm at gmail.com> wrote:
>>>>> sudo add-apt-repository ppa:grass/grass-devel
>>>>> you may need to install add-apt-repository using apt-get install
>>>>> On Wed, Sep 4, 2013 at 12:15 PM, Johannes Radinger <
>>>>>> Hi Rashad,
>>>>>> I just need your little help:
>>>>>> I added the grass-devel PPA to my repository and ran sudo apt-get
>>>>>> update
>>>>>> however there is no grass70 listed which I can install via apt-get
>>>>>> install gra*
>>>>>> There is a grass and grass-devel listed which seems to be related to
>>>>>> the grass 6.4.2
>>>>>> (is in the official ubuntu repo?)
>>>>>> On Wed, Sep 4, 2013 at 11:51 AM, Rashad M <rashadkm at gmail.com> wrote:
>>>>>>> Yes you are right. grass64 is uploaded in UbuntuGIS-unstable PPA
>>>>>>> when there is new release including RC's. GRASS PPA has daily builds for
>>>>>>> grass64, grass70 and grass-addons. I am sorry its not updated in grass
>>>>>>> webpage. I will ask Markus Netler who has can update this page [1]
>>>>>>> [1] http://grass.osgeo.org/download/software/linux/
>>>>>>> On Wed, Sep 4, 2013 at 11:48 AM, Johannes Radinger <
>>>>>>>> Thank you for the quick reply...
>>>>>>>> so just to be sure:
>>>>>>>> the grass70 is now located at GRASS GIS PPA.
>>>>>>>> the actual stable grass64 (643) is still located in
>>>>>>>> or also maintained for GRASS GIS PPA?
>>>>>>>> /Johannes
>>>>>>>> On Wed, Sep 4, 2013 at 11:28 AM, Rashad M <rashadkm at gmail.com>wrote:
>>>>>>>>> you can check grass PPA in ubuntu. I am not adding grass70 to
>>>>>>>>> ubuntugis-testing PPA because its getting deleted a lot of time. GRASS GIS
>>>>>>>>> PPA has daily builds for grass70 for raring and quantal. You can see
>>>>>>>>> details here - https://launchpad.net/~grass/+archive/grass-devel
>>>>>>>>> On Wed, Sep 4, 2013 at 11:15 AM, Johannes Radinger <
>>>>>>>>>> Hi all,
>>>>>>>>>> Hi Rashad,
>>>>>>>>>> I just checked the link that is provided here:
>>>>>>>>>> which points to the ubuntugis-testing repository
>>>>>>>>>> for downloading a precompiled GRASS70 package.
>>>>>>>>>> However, this repo does not include GRASS70.
>>>>>>>>>> Is there any way resp. any repo that contains already
>>>>>>>>>> an actual version of GRASS70 for Ubuntu or do
>>>>>>>>>> I have to compile it myself?
>>>>>>>>>> Usually I compile it myself but now I just set up a
>>>>>>>>>> very slim Xubuntu on a virtual machine for a collegue
>>>>>>>>>> and wanted just to simply install GRASS70. Any pointer?
>>>>>>>>> Regards,
>>>>>>>>> Rashad
>>>>>>> Regards,
>>>>>>> Rashad
>>>>> Regards,
>>>>> Rashad
>>> Regards,
>>> Rashad
> Regards,
> Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130904/3103c53b/attachment.html>
