[GRASS-dev] GRASS70 for Ubuntu in ppa
Hamish hamish_b at yahoo.com
Thu Sep 5 02:13:24 PDT 2013
you might have a look at the grass7 startup script to see why 7.0 is looking for anything in the old /usr/lib/grass64/* directory.
`which grass70` should tell you the file to start looking in. (eg /usr/bin/grass70)
be sure you haven't manually set the GISBASE environment variable to anything.
regards,
Hamish
Johannes wrote:
>Hi,
>yes grass-gui package is now also installed and this made grass64 working.
>However the grass-gui package did not solve the problem with launching the gui of grass70.
>Johannes:
>>> However when I try to launch both from the console (freshly installed
>>> precise) via grass64 or grass70 I get an error:
>>> python: can't open file '/usr/lib/grass64/etc/wxpython/gis_set.py': [Errno 2] No such file or directory
