[GRASS-dev] [GRASS GIS] #2034: GUI crashes on launch for newly compiled binary for Mac OS X
trac at osgeo.org
Thu Sep 5 12:33:58 PDT 2013
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: MacOSX
Cpu: OSX/Intel |
Comment(by wenzeslaus):
To summarize:
The discussion [http://lists.osgeo.org/pipermail/grass-
dev/2013-May/063806.html GRASS 7 crashes on startup on Mac] ([http
://osgeo-org.1560.x6.nabble.com/GRASS-7-crashes-on-startup-on-Mac-
td5052981.html nabble]) contains a workaround to get rid of the
`menudata.xml` error which is mentioned in the ticket.
dev/2013-August/065381.html no more GRASS 7 for Mac] ([http://osgeo-
org.1560.x6.nabble.com/no-more-GRASS-7-for-Mac-td5071809.html nabble])
extends the workaround because now there is a more than one file of that
type (generated `menudata.xml` from toolboxes files).
dev/2013-August/065482.html Mac OS 10.8: g.gui and DISPLAY]
([http://lists.osgeo.org/pipermail/grass-dev/2013-August/065482.html
nabble], originally named as "Max OS 10.8: g.gui and DISPLAY") mentioned
before and revisions r57536 and r57537 are important but unrelated to this
ticket.
The unrelated discussion [http://lists.osgeo.org/pipermail/grass-
dev/2013-September/065566.html Resources about compiling on Mac OS X]
([http://osgeo-org.1560.x6.nabble.com/Resources-about-compiling-on-Mac-
OS-X-td5076035.html nabble]) contains a detailed description of the
workaround.
cmbarton on ML:
Seem like this needs to be done in the GRASS-7.0.app. So you have to run
bindist first.
Then launch GRASS 7. The GUI will crash.
From the GRASS command line, cd to the ../gui/wxpython directory inside
the GRASS-7.0.app and run...
python core/toolboxes.py > xml/menudata.xml
python core/toolboxes.py "module_tree" > xml/module_tree_menudata.xml
Next, copy the newly created menudata.xml and module_tree_menudata.xml
files back into the binary distribution (in ../dist.x86_64-apple-
darwin12.4.0) and rerun bindist to make a new GRASS-7.0.app and *.pkg.
The reasons for and connections between the `menudata.xml` error (not
compiled XML file) and ctypes `__attribute__` error are still unclear. We
only know that you can get the `__attribute__` error and ''not'' get
`menudata.xml` error (tested on Mac OS 10.8) at the same time.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2034#comment:4>
