[GRASS-dev] [GRASS GIS] #2068: Saving the display as an image in wxGUI fails (was: d.out.file fails)
GRASS GIS trac at osgeo.org
Fri Sep 6 09:27:27 PDT 2013
 Reporter:  laurimyllyvirta  |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  normal           |   Milestone:  6.4.4
Component:  wxGUI            |     Version:  6.4.2
 Keywords:  display          |    Platform:  MSWindows 7
      Cpu:  x86-32           |
Changes (by wenzeslaus):
  * keywords:  => display
  * component:  Default => wxGUI
Comment:
 If I remember, this was fixed at some point. Can you please try to update
 to GRASS 6.4.3 and test there? (6.4.3 is the current stable release, if
 you want to test this bug also for development/svn versions such as GRASS
 7 you are welcome, but the update to 6.4.3 may solve your problem.)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2068#comment:1>
