[GRASS-dev] [GRASS GIS] #2069: List of GRASS 7 compiler warnings in libraries
GRASS GIS trac at osgeo.org
Sun Sep 8 06:57:34 PDT 2013
 Reporter:  neteler    |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:  7.0.0
Component:  Compiling  |     Version:  svn-trunk
 Keywords:             |    Platform:  Linux
      Cpu:  x86-64     |
 The attached file (compiler log reduced to the bare minimum)
 contains the current compiler warnings in G7, r57619.
 Some may be ignored but other (uninitialised variables)
 may potentially lead to troubles. These directories are affected:
  * grass70/lib/datetime
  * grass70/lib/gis
  * grass70/lib/raster
  * grass70/lib/external/shapelib
  * grass70/lib/gmath
  * grass70/lib/driver
  * grass70/lib/pngdriver
  * grass70/lib/cairodriver
  * grass70/lib/bitmap
  * grass70/lib/display
  * grass70/lib/db/dbmi_base
  * grass70/lib/db/dbmi_driver
  * grass70/lib/proj
  * grass70/lib/vector/rtree
  * grass70/lib/vector/dglib
  * grass70/lib/vector/diglib
  * grass70/lib/vector/Vlib
  * grass70/lib/vector/vedit
  * grass70/lib/vector/neta
  * grass70/lib/segment
  * grass70/lib/rst/interp_float
  * grass70/lib/lidar
  * grass70/lib/raster3d
  * grass70/lib/gpde
  * grass70/lib/dspf
  * grass70/lib/symbol
  * grass70/lib/cdhc
  * grass70/lib/stats
  * grass70/lib/arraystats
  * grass70/lib/ogsf
  * grass70/lib/nviz
  * grass70/lib/manage
Ticket URL: <http://trac.osgeo.org/grass/ticket/2069>
