[GRASS-dev] [GRASS GIS] #2067: PyGRASS grid calls g.region at import time
trac at osgeo.org
Mon Sep 9 14:23:07 PDT 2013
Reporter: huhabla | Owner: grass-dev@…
Type: defect | Status: closed
Priority: blocker | Milestone: 7.0.0
Component: Python | Version: svn-trunk
Resolution: fixed | Keywords: wingrass, PyGRASS, Grid, Python, temporal framework, t.remove, t.rast.neighbors
Platform: MSWindows 7 | Cpu: Unspecified
Changes (by zarch):
* status: new => closed
* resolution: => fixed
Comment:
Sorry for the late replay but I was in holiday.
As pointed out by Hamish, when we instantiate a Module object with:
Module('g.region')
We are only run the module with the --interface-description and then
parsing the xml, I want to avoid to do these operation inside a cycle.
Now should be fix.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2067#comment:4>
