[GRASS-dev] [GRASS GIS] #2072: Unable to load workspace.gxw in 3D View
GRASS GIS trac at osgeo.org
Mon Sep 9 23:15:29 PDT 2013
 Reporter:  richardc  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  7.0.0
Component:  wxGUI     |     Version:  unspecified
 Keywords:            |    Platform:  Linux
      Cpu:  x86-32    |
Description changed by martinl:
Old description:
> I'm unable to load the workspace.gxw file in GRASS 7 (57592)
> I receive the following error:
> Reading workspace file </home/user/RESEARCH/workspace_ ..GRASS7nviz.gxw>
> failed.
> Invalid file, unable to parse XML document.
> Reason: invalid literal for int() with base 10: '7000.0'
> Traceback (most recent call last):
>   File "/home/user/grass7/grass7_trunk/dist.i686-pc-linux-
> gnu/etc/gui/wxpython/lmgr/frame.py", line 1113, in LoadWorkspaceFile
>     gxwXml = ProcessWorkspaceFile(etree.parse(filename))
> gnu/etc/gui/wxpython/core/workspace.py", line 58, in __init__
>     self.__processFile()
> gnu/etc/gui/wxpython/core/workspace.py", line 149, in __processFile
>     self.__processLayers(display)
> gnu/etc/gui/wxpython/core/workspace.py", line 176, in __processLayers
>     cmd, selected, vdigit, nviz = self.__processLayer(item)
> gnu/etc/gui/wxpython/core/workspace.py", line 238, in __processLayer
>     nviz = self.__processLayerNviz(node_nviz)
> gnu/etc/gui/wxpython/core/workspace.py", line 378, in __processLayerNviz
>     nviz['vector']['points'])
> gnu/etc/gui/wxpython/core/workspace.py", line 443, in
> __processLayerNvizNode
>     value = cast(self.__getNodeText(node_tag, 'value'))
> ValueError: invalid literal for int() with base 10: '7000.0'
> After deleting the following, the 'Please wait, loading workspace' notice
> remains visible and layers are not loaded into the 3Dview.
>  <size>
> <value>7000.0</value>
> </size>
> I also notice in the command console, not sure if relevant:
> Loading raster map
> <srtm_cgiar_mosaic2_cp_int16 at PERMANENT>...
> Translating colors from raster map
New description:
 failed.
  <size>
 </size>
 Loading raster map
Ticket URL: <https://trac.osgeo.org/grass/ticket/2072#comment:2>
