[GRASS-dev] [GRASS GIS] #2067: PyGRASS grid calls g.region at	import time
    trac at osgeo.org
    Mon Sep  9 23:17:17 PDT 2013
  Reporter:  huhabla      |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  blocker      |   Milestone:  7.0.0
 Component:  Python       |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  wingrass, PyGRASS, Grid, Python, temporal framework, t.remove, t.rast.neighbors
  Platform:  MSWindows 7  |         Cpu:  Unspecified
Comment(by martinl):
 Replying to [comment:4 zarch]:
 > We are only run the module with the --interface-description and then
 parsing the xml, I want to avoid to do these operation inside a cycle.
 Now should be fix.
 right, seems to be fixed (1). Thanks.
 (1) http://wingrass.fsv.cvut.cz/grass70/logs/log-r57623-698/error.log
Ticket URL: <http://trac.osgeo.org/grass/ticket/2067#comment:6>
