[GRASS-dev] [GRASS GIS] #1778: Typing in g.region without parameters does not open a g.region window
GRASS GIS trac at osgeo.org
Wed Sep 11 10:53:10 PDT 2013
 Reporter:  pvanbosgeo                  |       Owner:  grass-dev@…
     Type:  defect                      |      Status:  new
 Priority:  normal                      |   Milestone:  7.0.0
Component:  Default                     |     Version:  svn-trunk
 Keywords:  g.region, r.colors, r.mask  |    Platform:  Linux
      Cpu:  x86-64                      |
Comment(by glynn):
 Replying to [comment:25 martinl]:
 > any objection to committing this patch?
 Not really, although I note that we don't list --help, --script or any of
 the --*-description options either.
 I suppose that --script and --*-description aren't of interest to end
 users, and if you're reading the help text, you probably don't need to be
 told about --help (although it would be nice if we could train users to
 use that so that we can remove the argv[1]=="help" check; although "help"
 isn't likely to be particularly common as an option value, I dislike
 having special cases on principle).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1778#comment:26>
