[GRASS-dev] r.surf.idw not workin in GRASS 7?
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Thu Sep 12 11:30:29 PDT 2013
Hi
I am having problems with r.surf.idw in GRASS 7.
When I run it on a small dataset the module finishes almost immediately but the resulting map looks identical to the input map...
Using r.surf.idw in GRASS 6.4.3 works fine and the result looks as expected...
Are others facing the problem too? If the latter is the case, shall I file a ticket?
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130912/620b7087/attachment.html>
