[GRASS-dev] [GRASS GIS] #1941: wxGUI fails with Japanese locale --> mixed Python installs on Windows
GRASS GIS trac at osgeo.org
Thu Sep 12 20:32:27 PDT 2013
 Reporter:  venkat    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  7.0.0
Component:  wxGUI     |     Version:  svn-trunk
 Keywords:  wingrass  |    Platform:  MSWindows 7
      Cpu:  x86-32    |
Comment(by glynn):
 Replying to [comment:26 hamish]:
 > As seen in the pdf screenshot, the trouble comes with "import re", which
 I think(??) is a built-in.
 re.py and sre_*.py are part of the standard library. The error comes
 because MAXREPEAT is expected to be in the binary module "_sre", which is
 built into python27.dll. This is getting loaded from the Windows/System or
 SysWOW64 directory, hence the problem.
 > Are we prepending to the PYTHONPATH instead of adding the grass paths to
 the end of it? (hopefully the GRASS versions get picked up first then)
 AFAIK env.bat & friends in the stand-alone installer now explicitly set
 GRASS_PYTHON with with the full path to grass's python.exe.
 I don't know whether imports from the standard library use PYTHONPATH or
 PYTHONHOME (and neither of those will affect binary modules built into
 python27.dll).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:27>
